1 - 12 of 12 Posts
As the title says, I have a set of 5mm spacers from MotorSportTech that have never been used. They are hub-centric to hub and wheel-centric to wheel.
5x108, hub-centric to 63.4 mm hub, wheel-centric to 73mm wheel.
$65 shipped conUS.
They might be hubcentric but there is no way a 5mm spacer is wheel centric. Just sayin.
I've seen much wider spacers. In fact, I'm planning on running 10mm, that's why I'm selling these.
Yeah, I figured I would probably go with 10 or even 15 in the back. Good luck with your sale!
FYI - dont go above 5mm without using extended lug bolts.
It's because it changes the required center bore of the wheel.
The hub side is 63.4 so for the s40 but the wheel side is 73 so you need wheels with h larger center bore or change the rings.
Sent from my Nexus 4 using Tapatalk 2
1 - 12 of 12 Posts
