I've got to clean out the closet and make room in the apartment. Over the last five years, I have had an assortment of Volvos and I need to pass along my parts collection. I have outlined below the parts, which model, and items numbers from IPD or VPAutoparts. I am located in San Luis Obispo, CA and would prefer to pass the whole lot along to someone local. If you would like a specific part out of the list let me know and we can make a deal and arrange shipment.
Happy Volvo days! Hopefully, these parts can keep your project on the road
Car Description Item No.
740 Windsheild Reflector
740 Transmission Flush Kit 105310
740 Trans Filter FT1112
740 Seal FT Timing Cover (OE) 101487
740 Seal Cam & Cayshaft 101450
740 Fuel Pump Relay, Uro 3523608
740 Multi-Purpose Relay 1323592/252
740 Calorstat Thermostat Air Filter HSG 103083
740 Throttle Body Gasket 105055
740 Spark Plugs 101138
740 Wire Set 101527
740 Fuel Filter w/ O-Rings 0 450 905 601
740 HD IPD Springs 112590
740 BILSTEIN R 700/900 ALL X-IRS MODEL 100185
122 Stainless Steel Brake Lines 102019
122 Headgasket Set B18 101374
122 Gasket Set Pan B18/20 101407
122 Valve Cover Gasket 419678
122 MS102 Generator Mounting Kit 403877
122 Misc Windlace
122 Heater Core Gasket Kit 658721
122 Water pump Gasket and Seal Kit 2K1850
122 SU Rebuilt Kit 110323
122 Fuel Hose
122 Front Brake Pads 100790
122 Fuse Kit 273589
122 Dome Light 662109
122 Uni-Syn Carburetor Synchronizer
122 Rear Differential Gasket 101396
122 Fuel Filter 100269
740 Wire Set 101527
122 Misc Windlace
122 Fuel Hose
122 Fuse Kit 273589
