1 - 17 of 17 Posts
Looks very mean! Unfortunately I dont think these will fiy an R. Can you find out?
I don't have any friends with an R to do a test fit... Just an 01 s60 T5 HPT.
Are you concerned about the callipers, suspension or the fenders?
Everything and bore size too
Sent from my SM-G730V using Tapatalk
These are 17 lbs?!!! Wow. I thought rpf1s would be lighter
Bore size is somewhere around 72mm which is plenty oversized. The wheels include hub rings for p1 chassis but you can always source hubrings to fit an R.
I have not been able to find anyone with a p2R to test fit. I only have access to a P1T5 but that wont answer whether or not they will clear the Brembos :(
Test fit on an R today, will not fit without a 10-15mm spacer. The caliper clears the barrel and such but the edge of the caliper contacts the spokes near the hub. Moving it out with a 10-15mm spacer will allow enough clearance to fit an R.
BUMP, PRICE DROP 1400 FIRMMMMM. ADDED NEW PICS TO SHOW WHEEL CONDITION.
Will likely not lower the price any further. Price will likely go back up in spring when the demand is up.
wish you were selling in spring time, would grab them in a heart beat
Well, if I still have them then I'll let you know. Hoping it won't come to that tho, as I'm trying to pick up my next vehicle before the snow starts falling.
I'm wondering if you can fit a 315 with that offset
Discussion Starter · #14 ·
On a c30? I think inner clearance is maxed out at a 265-275 depending on which suspension you are running. Outer clearance would be entirely up to you to figure out since I can guarantee a 275 would not fit under a c30's fenders in stock form.
I wouldn't mind poke plus raise it a bit.
Continuing my chat with you on insta ;)
Sent from my SM-N900P using Tapatalk
1 - 17 of 17 Posts
