Hello, I have a 2010 S40 r. I've just replaced:
Tie rod ends
front lower control arms
Front right wheel bearing
Rotors
Brake pads
It's tighter but something is still loose in the front end and it's driving me nuts.
You you help me narrow this down on what needs to be replaced still ?
Thanks
Definitely check front right engine mount. Gently jacking up the oil pan to apply some stress, then checking for tears/separation with a mirror is how I inspected mine. Cursory glance, it will of course look fine. The damage happens on the bottom. It was making a nasty bad clanking over repetitive high speed bumps. I thought the wheel was going to fall off.
Thank you both.
The looseness . . . Always as I am turning into my driveway which is a left turn going slowly it feels like a left to right movement in the front left.
Have you checked sway bar end links? Over the littlest bumps it will make lots of metal clunk noises and steering will feel off. I did that and my engine mount since my mount was split in half causing clunking when shifting.
