This squeak has been getting progressively worse over the last few months. At first I only noticed it occasionally, ... thought it was temp/humidity related.
I believe that the noise is coming from the control arms. Just a bit of a bounce on the front of the car produces the squeak. It's very noisy now, and driving around the rough city streets in my neighbourhood is beyond annoying.
Am I right in my diagnosis?
Is there any cure, or will I need to replace the control arms.
( The Struts and strut mounts are new OEM ).
Thanks
Discussion Starter · #2 ·
Re: Front Suspension Squeak (IceBrick)
I jacked one side up, removed the wheel and put a jack under the control arm. There is no noise until the arm is up at it's normal loaded position.
Still not sure where the noise comes from.
If you don't know what you're doing, take it to a mechanic.
Being that the the noise can be heard, I'm sure he will tell you what it is in 5 minutes
