Can the front subframe be moved left or right relative to the chassis? I noticed that both front wheels are sitting about 5mm left of center, relative to the fender wells.
I know there is an alignment pin, but is it only at one corner?
There are two alignment pin on the left side. There is a ever so little amount of movement that could be adjusted it one were so inclined.
I was able to move it a tiny bit...even a tiny bit helps. With these new wheels, I'm rubbing on the top of fender well but only on the left side. It's really cramped in there!
