Looking for front struts to fit 2001 S60 Turbo - must be in good condition with no leaks.<p>Thanks
Re: Front struts to fit 2001 S60 Turbo (S60inToronto)
As I've said before and will say it again, <B>NEVER install used shocks/struts on any car.</B><br>The labor time makes this not worth it, to have to do all over again in a few thousand miles!<br>The other reason would be is used struts are usually no good anyway.<p>The only exception would be aftermarket's like Konis or Bilsteins that were removed for some reason with under 5000 miles on them.<p>Just go buy a new pair of whatever brand you want to use and be done with it.
Thanks....one of mine has a leak (driver front) and I'm selling the car so may swap it out if required to pass safety/certification.<p>If I was keeping it I would definitely do new upgraded struts.<p>Timing belt is also due so I will give the potential buyer the option to do it themselves or I may do it (if I can find instructions <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> )
Re: (S60inToronto)
Call Erie<br><A HREF="http://www.erievovo.com" TARGET="_blank">http://www.erievovo.com</A>.<br>I'm sure they will sell you one strut cheap as not many people need used struts
