Does anyone know what size the front rotors are on the 2001 V70 T-5's are? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Measure them straight across the center. They are either 280mm (11'') or 302mm (11 7/8") and probably the larger ones, which tend to be on the newer turbo models, like your T5, but Volvo did such screwy things that they fitted some with the smaller ones and others with the larger ones, so to make sure, you better measure them before ordering.
Re: (MadeInJapan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MadeInJapan</b> »</i></TD></TR><TR><TD CLASS="quote">Measure them straight across the center. They are either 280mm (11'') or 302mm (11 7/8") and probably the larger ones, which tend to be on the newer turbo models, like your T5, but Volvo did such screwy things that they fitted some with the smaller ones and others with the larger ones, so to make sure, you better measure them before ordering. </TD></TR></TABLE><p>2001 V70 T5s had 302mm front rotors.<p>Yannis
