Has anyone installed the Front LOWER Small Engine Mount made by PowerFlex?? Was it as easy as changing out the upper Mount?? Did you notice any difference? Did you need to support the motor with anything when the mount was removed??
Discussion Starter · #2 ·
Re: Front Lower Small Engine Mount (s60rdood)
Well, I ordered it from Viva just now, so it should be here this week, after putting it in, I'll give a report of any and all changes it makes.....I already have the EVOLVE Blue Upper Mount and IPD Cross-Mount Bushings, so in combination with the Lower Mount, should really give a solid feel......let's just hope not too much.
It doesn't hold the engine up, it just damps movement (it will be QUITE obvious when you look at the design of the mount)<p>
Re: Front Lower Small Engine Mount (cschmelz)
Check this <A HREF="http://forums.swedespeed.com/zerothread?id=56567" TARGET="_blank">thread</A> out.<p>Denny
