My 2009 s80 t6 has developed an odd front end rattle.
If the car is neither accellerating nor slowing, the rattle really obnoxious, getting on the gas will cause the rattle to go away. Lifting off the throttle, briefly makes it worse.
I'm thinking sway bar end links? Has anyone experienced similar symptoms?
Thanks
Gary
I would probably start there since those are quite easy to replace. I had the same on 2 of my cars and this solved my issue on both.
Could also be the torque rod motor mount on the top left of the engine.
I had a popping sound and it turned out to be suspension.
