1 - 8 of 8 Posts
quick question: do we have wear sensors/indication on the front pads, or only the rears?
There are no wear sensors or indicators on front or rear brakes.
Thanks. So it's just the pad wear groove from the side? and can I get a visual without taking off the wheels, maybe with a mirror?
You can usually see the outer pad through the wheels. I use a small inspection mirror to check inners. If they look close, I pull the wheel and measure.
Discussion Starter · #6 · (Edited)
This all started when my wife just complained about grinding brake noise 2 days ago. I drove the car and heard it on the front right side, with or without braking, rolling in neutral or in drive. I know the pads should be good, as she drives only 5kmi/year total and a very defensive and smooth driver. last inspection was 3kmi. ago and pads had well over 50% life on them. Car now has only 29,000mi total. So I looked around, underneath, did not find any scoring on the disk, so just kicked the tire few times. The noise changed in pitch when I drove again and suddenly stopped. Not sure if it was a stone, or maybe pads got stuck on the rotor because I washed the car 2 days prior?
Very strange.:confused:
I am thinking you may have had rust on your rotors that got cleaned off after braking a few times.
You might be right. I drove it yesterday again for over 50 miles, and it's dead quite-all normal. I'ts my wife's car, so I rarely ever drive it. I sure enjoy driving this T6, and my wife absolutely loves the XC70. It's our first volvo.
Now she wants me to get rid of my Jag and get a volvo also.......Not sure about that.
1 - 8 of 8 Posts
