1 - 11 of 11 Posts
Very cheap s70 T5 sway bars...
I've just had the ipd sway bars installed, if anyone needs stock sway bars let me know, otherwise I do not see any reason why I should keep them.
Make me an offer.
Modified by dicostal at 5:34 PM 3-28-2006
Don't think you'll sell them here but they make a great upgrade for a NA (normally aspirated) S70 or older 850 that is also an NA ('93). I would put them over on the volvospeed forum in the sales section. You should be able to get $60-75 for these. In fact I sold mine to an 850 owner for right about that amount plus shipping.
Re: (MadeInJapan)
Thank you MIJ, I was not looking to make any money off of these, but I will definitely take a donation
The higher offer takes them.
I'll clean them up and post a couple of pictures.
Thanks
The will work on the NA '96 as long as it's an 850 ...though from an S70, the rears would be different than an 850 wagon, so the rears will only work on an 850 sedan, although the fronts will work on either sedan or wagon. Hope this helps. BTW, the T5 swaybars are stiffer than most (not 850 R or T-5R)....would be a very nice upgrade for an 850 in general...not just an NA.
Re: (johhnyvolvo)
Quote, originally posted by johhnyvolvo »
Thanks, I have a set of IPD endlinks for v70 - will those work with these sways on the same car ('96 850 NA)
YES, as long as they aren't endlinks for '01 and newer V70's.
Re: (MadeInJapan)
Quote, originally posted by MadeInJapan »
there is no difference between wagon rears and sedan rears.
1 - 11 of 11 Posts
