1 - 6 of 6 Posts
Discussion Starter #3 (Edited)
i can, lol trust me its not moving, its heavy as ****, realize that all of the lines to the motor were cut on removal. oil, coolant, wiring harness. the turbo is off of the motor as is the fuel rail, intake manifold and injectors, all of which i have, they're for sale on my other thread. the timing belt cover is cracked and the serpentine belt is missing. it needs a pcv system if you plan on using it. other than that, the engine internals are in great shape for 164k
how long do you need it held? i want it gone in at most 4 weeks. if you're taking it, know you'll need to remove the transmission here so i may keep it. cheers.
it'll be less than 4 weeks before its picked up. seal it up for me. like put tape over the holes in the engine. ill send you a pm
1 - 6 of 6 Posts
