Figured I would chime in on this as I just went threw this whole 4c mod dance. It's hard to describe suspension setups in terms of feel as everyone has different ways they like their car to ride, but one thing that seems to be universally loathed is the "Crashyness" of the 4c. So bare with me here.
I just got my 06 Vr back in August. All of the struts are Monroe replacements with around 15,000 miles on them, they all work perfectly with no codes or other issues. All of the spring seats, control arms and other associated bushings are in good condition or new. The tires are brand new "Vouge" brand (I have no idea why the PO put these specific tiers on) 235/45/17 running 35psi cold. I have IPD sways front and rear. I live in Boston where the roads are **** so I do most of my driving in Comfort mode. I would say I drive spiritedly.
OK. When I first got the R it came as described above and had TME springs front and rear that were essentially new. The car was a bit low for my taste but the ride was quite good if a little on the firm side. It didn't ride so much like a car on lowering springs, but you could tell that the suspension had limited travel going over large heaves and potholes. Tho there was no crash to the suspension what so ever and it handled very well. I would describe it as composed but on the firm side with no crash and no side hop.
I wanted a softer ride so I put the original springs back in and wow did it ride terribly. While the ride was softer the car felt really unsettled over large road imperfections and it crashed horribly over expansion gaps and large pot holes. With the TME springs the ride was firm but composed and consistent, now it was soft sometimes then super hard over some bits, then back to soft and disconnected. Comfort was too nerve racking to use (as you didn't know what would cause a sudden full hard suspension decision followed by a crash), Sport was better but it was still a bit crashy and almost firmer than Sport using the TME springs but in a really bad way. Oh and I started to get side hop on some onramps and it scared the **** out of me the fist time it happened.
So desperate I did the 4c mod moving the front accelerometers located on the struts to the body. This both solved the crash problem by about 90 -95% and made the car super soft and wallow quite badly in comfort. So now Comfort was very soft, I would even say the car wallowed too much. The body roll was noticeably increased as well. I found myself using Sport more and more, but this was less than ideal as it both was a bit too stiff while still having too much body roll. I will say that if I had a choice between stock springs with no mod and stock springs with the mod I would choose the mod as it made the car overall way less harsh to drive even if it made everything a bit too soft in all the wrong ways. It did get rid of the side hop tho.
In a bit of experimenting I got a pair of Lesiofors "HD" front springs for a FWD/AWD P2 car off of FCP. The idea was I would get the added height I wanted (I'm not a fan of how low the stock springs were), increase the suspension travel and have a stiffer spring rate which, going on how well the stiffer TME springs compared to the softer stock springs, should give me the best of both worlds. So I put in the Lesiofors front springs and left the stock rear springs in place, put the accelerometers back in the stock position and have been driving like that for the past few months. I LOVE it. There is no crash to the suspension and I have better handling than the stock springs with a much much better ride quality to boot. There is no side hop at all.
Comfort now is very composed and predictable, there is no float and no side hop. Just the initial compression and rebound without the extra up and down movement that the stock springs and 4c mod seemed to do. Uneven surfaces are ironed out, pot holes are absorbed quite well, expansion joins are a non event, and the body is controlled in line with what you would expect a regular sedan might do.
Sport is also composed and predictable, firmer than Comfort but that's to be expected. Still rides well over broken surfaces just firmer with less body roll. Makes corners super fun.
Advanced is very good for spirited driving, especially on ramps. It is stiff, but I wouldn't consider it crashy. Odd thing is Advanced rode better with the TME springs over every other configuration I tried.
TME on the bottom, Stock in the middle, Lesiofors on the top. For anyone interested the part number is 9465472 and the link to the FCP page is https://www.fcpeuro.com/products/volvo-coil-spring-v70-4095831
The look is not for everyone. It raises the car about an inch, but my stock springs were way low to begin with so take that for what its worth. I love the extra ground clearance and I quite like the way it looks raised up.
Overall I really like these springs and I think this is how I'm going to leave it. I will get better tires with probably a softer and taller sidewall to give myself just that extra bit of comfort, but I'm really happy with it in its current state.
