1 - 11 of 11 Posts
Re: Found Some Headlight Wipers FS on Ebay (jrocheunh)
quote:
why is that?
"The item you are bidding on is the headlight wiper setup for a Volvo 240 equipped with the early large rectangular headlights found on European models. I included a picture of the headlights that these wipers fit." -quote from auction page
quote:
It's too bad they fit about .001% of the 240s on US roads.
why is that?
Those lights fit the pre-'86 200 series models, which are the same as some European models from about '78-'80. Just finding those headlights is not easy, and the dual round/rectangular headlights can be upgraded cheaply w/o buying the big euro lights, so most people don't bother with them. There just aren't many 240s out there that have these lights in the US.
Re: Found Some Headlight Wipers FS on Ebay (towerymt)
Okay, but feasibly, wouldn't they fit an '86-'93 with the big ole plastic aero lights?
Re: Found Some Headlight Wipers FS on Ebay ([email protected])
They may fit, but would only work after you shave off the nipples http://********************/smile/emsmileo.gif and even then they would cause scratches on the plastic so it's not a good idea.
edit: HOWEVER, for those with clear (I mean CLEAR) plastic lights, these would add a nice european accent to the car, but I wouldn't recommend using them.
No, they won't fit. They were designed to swing down rather than wipe up. There is no place to properly mount this design.
That's why I said it was too bad. I'd sure like a set of the ones that fit our models. They look very delicate though. The ones on my Saab worked really great...I miss those.
Re: Found Some Headlight Wipers FS on Ebay (ACD)
I wonder if the ones from the 850 could be used? They swing up, but the 850 headlight is lower profile than the 240. Plus...there's the scratching Michael mentioned.
Volvo omitted the headlight wipers because they decided to make our headlamps plastic. I have no clue as to why. My Saab had glass headlamps which did not scratch. I did find that the wipers would skip over the aiming nipples. Very annoying. My solution was to cut a little piece out of the wiper rubber. Worked great after that.
I like the idea of the 850 wipers. They might actually work. Now there's the trouble of finding all the parts.
1 - 11 of 11 Posts
