God, I love this stuff! Restored my lost compression in half the cylinders in my old 850 (Half of 5?) and gave me some great low-end power in my S60!
But... I think I used too much. Now I have a check engine light...
Thanks guys!
Quote, originally posted by nathancarter » |
How did you use it? |
Quote » |
Depending on your methods, The Check Engine light may be from a vacuum leak (of course, since you had an intake hose disconnected), or maybe a misfire or two from having that stuff in the cylinders. |
Quote » |
Did you get a big black smokescreen when you wound it up the first time after treatment? I sure did. Haven't done it on the S60 yet. |
Quote, originally posted by DGBibo » |
what vacuum hose did you pour it in? any pics? |
Quote, originally posted by jstro » |
Did you get the check engine light inthe 850 or S60? Also did you use in your gas tank, crankcase, & intake? |
Quote » |
I also am curious as to what hose you used to suck into intake. |
Quote » |
Finally, you did change your oil right away after treatment, correct? |
Quote, originally posted by StarmanDXE » |
Long time, no see!
![]() ![]() Code's gone now on it's own, but maybe that was it. BTW, Bender: LMK if you'd still like some pretzels ![]() ![]() |
Basically, all you do is: - Pull the vacuum hose connected to the intake manifold. - Suck the Seafoam in while it's idling. (I had another ~2 foot hose which I plugged onto the inlet there.) - Shut the engine off and let it sit for a bit (~20 minutes?). - Drive around in 1st gear until your tailpipe stops smoking! |
Quote, originally posted by JRL » |
Doylestown?
![]() I'm delivering an S4 on Sat |
NO This is NOT how to do it. You put 1/3 can into a vacuum line as was said, you put 1/3 into the oil fill and 1/3 into the tank. You run the car, you do NOT drive it around, (it's a smoke bomb) for 20 minutes or so, or when the smoke CLEARS, THEN drive it for 50 miles and change the oil. |
Quote, originally posted by Rezin S60T5 » |
OK, I am shocked. I have heard of seafoam mentioned, but I always dismissed it as something akin to "Marvel Mystery Oil" and that's it. So this stuff actually works? hmmm. Maybe I'll give this a shot myself, I know the T5 will appreciate it. I been promising her some love! |
