In looking for ways to help my G-tech Pro RR g-meter pick-up the RPM signal in my MY06 R I came across a new and very easy way to get wires from the engine bay to the passenger compartment.
Open the driver's door and remove the panel to expose the fuse panel. Look for and remove the foam plug. Carefully remove the large rubber grommet behind the driver's door hinge, be very careful not to drop it and lose it inside the body of the car!
Here are the pics:
(deleted original photobucket links and attached pics below)
Here's where you arrive in the engine bay (through an existing hole):
Roll/squish the foam plug and put it back in the hole, it will expand back to size in a few minutes (it's just like those foam ear-plugs you use when you watch the Alcohol and top fuel cars drag).
The final step would be to cover the wires with some black split-loom tubing and if you use a large enough one it could also serve as a conduit to pass future wires through (pull a back string to make it easier).
This route was WAY easier than opening the cowl under the windshield or
contorting myself to snake through the firewall near the clutch peddle.
LTA
Modified by LTA at 12:09 AM 3-16-2010
Here are the pics:
LTA
