1 - 20 of 100 Posts
i dont want this thread to be full of opinions, the debate of DRLs has been discussed many times in many threads so lets not turn this into an argument. at the end of the day,
it is perfectly legal to disable your DRLs in the United States, and volvo has a software package that allows you to do so.
the software code you want is 30679690, from viewing other threads of successful disables, it is the same code as the previous model years.
there are plenty of reasons why a dealer might tell you its not possible, laziness, lack of time to figure out a process they aren't familiar with, predisposed opinions on the matter etc. etc. etc.
if your service dept tells you it is not possible. politely tell them there is a software code made by volvo that they can simply download and transfer to your vehicle.
in some cases they will do it for free, but most likely you'll be charged for the software (them finding it in their network) and about 1/2-1 hour of labor.
in my case the software ($35) and half an hour of labor ($75) i ended up spending a little more than a hundred bucks. a bit high compared to others out there but i live in a pretty wealthy city (Marin Volvo). i'm sure with some polite haggling you can get it for less than one hundred.
let me know if you folks have any questions (not opinions)
cheers
I have a question. When you have your light switch facing up (auto) will your lights still come on/turn off with the ignition, or do you have to turn the switch to the down position to get them to come on once you start the car?
Re: (ElectricSilverT5)
in the top/ auto position, the lights will turn on/off automatically when you switch your car on/off. i discovered this because i took my car home and left the lights in the on position (still used to DRLs
) and the next day i noticed they were on when i pulled into work.
in the parking light position just the parking lights will be on.
in the 0/off position, none of the exterior lights will be on.
in all 3 positions, interior lighting will automatically adjust to exterior lighting conditions. so lets say, if you're driving at night in the "0" position, your interior lighting will adjust to night lighting, but your exterior lights wont turn on until you swtich them on.
http://********************/smile/emcocktl.gif
Re: for the record; 07 DRL disable IS possible (max power)
Technically they don't disable anything, they just load a different headlight application(perhaps for Euro. cars w/o DRL).
What's more interesting is how it works:
Light switch has 3 positions w/ only 2 triggers. 1st trigger for DRL and second for Parking lamps. The third switch position(low beam) is "open", which means even when you disconnect the switch completely the CEM activates low beams automatically. So to turn off the lights completely you need to reprogram CEM's DRL trigger, so when it's triggered the CEM turns the light off.
Can anyone shine some light on how their OEM bi-xenon's work. Do you still have DRL? can you disable it? Is there any bi-xenon applications for CEM or is it just for the GDL module? (according to parts list there's no application for bi-xenons only for halogen)
One more: Is it possible to completely uninstall Low Beam Application for halogen bulbs? (If yes, what happens?)
I asked about having my DRLs disabled in my '05 V50 (halogens) and they said it would be about $135 total.
Stan
Modified by AutoGeek at 10:27 AM 3-20-2008
Modified by AutoGeek at 10:28 AM 3-20-2008
Re: for the record; 07 DRL disable IS possible (AutoGeek)
That's about right for the price.
Quote, originally posted by AutoGeek »
I asked about having my DRLs disabled in my '05 V50 (haloges) and they said it would be about $135 total.
Stan
yea up until your quote, my price i paid was the highest i've ever seen. i bet the variation comes from the rarity of this request. the way i see it a dealer has two options when confronted with this request
1- they can see it as a simple software download and charge you just labor
2- they can see it as a money making opportunity and pile it on. thats what happend in my case, i think i was quoted 180 initially, but when i asked him to break it down i got the typical "uh oh i made up my own price now i have to explain it" pause in the conversation. after telling him about my internet research he told me he'd call me back with a price summary.
I had them go ahead and disable my DRL as I figure it will save me in bulbs and if I switch to PIAA's or HID it could pay for itself.
Part#
30679691-3 Low-Beam 3 Appl Price (Internal)
30679689-7 Low-Beam 1 Appl Price $26.75
Total for parts and labor was $121.75.
RE: Daytime Running Lights
I own a 2009 Volvo S40 2.4i
I recently called my Dealership and they said they would disable the daytime running lights for me
with no problem and quoted me an excellent price to do it. It sounded as if they had done it before and it would only take a few minutes.
After bringing the vehicle in, and waiting about 20 minutes or so, they said they couldn't do it??? I was really surprised to hear that since the whole time he sounded confident.
I also wanted to have my headlights adjusted higher and, once again, he said something about you need a special model to do it and...yours dosen't have an adjustment????
WTF????
Is the dealer blowing me off???:mad:
Someone help me...Thanx
Yes, sounds like a line of crap to me. It's simply a software upgrade, as stated. And your headlights are certainly adjustable, I did both mine (05) and my sister's (08). You have to remove the headlight to get good access to the gear used to adjust. There's a thread in here somewhere.
Ive done at least a dozen of these downloads so far, ranging from 04.5's up to 09's. They just dont know which light application software number to use since there is generally 3 available and none have a description as to what they do.
I had to figure it out based on trial and error and process of elimination. The other giveaway is that it doesnt apply to Canada which makes sense due to DRL's being government mandated.
For the record its Low-Beam 2 Application part number 30679690 for MOST P1's looking to remove DRL's.
That is weird. Mine were 30679691-3 Low-Beam 3 Appl , 30679689-7 Low-Beam 1 Appl for my '05 V50.
how much did you pay for that stan? Those are the two part numbers I need to load? Because i'm going down to a US dealer to have a key programmed, so it'd be nice to get this done too.
Is that for no lights position 0 running lights position 1 and low beams position 2? Because that is the sequence I get for low beam app 2.
ForceFed, How much would I be looking at to have you disable my DRLs at your work? Pretty please?
The SW is 30$ and then I worked a deal for .3 labor so roughly 60$. I was just loading them on my lunch break but service wanted their cut lol.
1 - 20 of 100 Posts
