Hey all,
Maybe I'm just dumb or did something wrong, but I swapped out the oem bulbs in the foglights to some from autolumination. Now my foglights won't turn on. They worked great before. I'm going to troubleshoot in the morning if I have time, but I'm kind of bummed. I was looking forward to non-yellowy foglights...
Here are the things I DID do, just so folks aren't like "well did you do X?"
-I did get the right type of bulb [55w H3 bulb]
-I did plug the white lead to the same spot where the oem one was.
-I did plug the red lead to the [I assume] ground plug below the socket
-I did disassemble and reassemble the lights correctly
At this point, I have no idea why they would all of a sudden not like new light bulbs. What's also weird is that after I swapped one bulb and reassembled, I turned the car on and tested to see, cause I was curious how the two colors would compare. Thing is, neither foglight turned on at that point. I went ahead and swapped both bulbs, hoping it would work when I was done. No luck. Didn't work either on my drive home.
Has anyone ever had this happen? Since they're not a monitored system by the car, I get no message indicating a problem :facepalm: Could this be as simple as a blown fuse? What's the fuse number for fogs on an 04R?
Thankfully this isn't a major system failure, just an annoyance
