1 - 14 of 14 Posts
Re: am i stupid or....? (p0cket penguins)
More like 7
Re: am i stupid or....? (JRL)
crap i can only turn my liek 2 or 3 turns. its that one long screw with a plastic knob on it right?
Yep.<br>Maybe it's already turned 1/2 way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>p0cket penguins</b> »</i></TD></TR><TR><TD CLASS="quote"> its that one long screw with a plastic knob on it right?</TD></TR></TABLE><p>Yeah, it's directly behind the fog light assembly. Just to make sure that you covered all the bases, the knob can be turned about 7 times total from the highest to lowest point as JRL said, but maybe your lights were somewhere in between and so that's why you are only getting 2-3 turns?<p>Also, is this happening with both fog lights?
Re: am i stupid or....? (Vipergtsz3)
yeah i turned it from one end to the other and its about 2-3 turns and happens on both fogs when im parked 5-6 ft from my garage door i have a 8 in gap between the low beams on the xenons and the fog lights<br>
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>p0cket penguins</b> »</i></TD></TR><TR><TD CLASS="quote">yeah i turned it from one end to the other and its about 2-3 turns and happens on both fogs when im parked 5-6 ft from my garage door i have a 8 in gap between the low beams on the xenons and the fog lights<br></TD></TR></TABLE><p>One mans "turn" might be another mans 360 degrees! So to calrify are you calling a turn one twist of the fingers or a full 360 degree rotation?
Re: am i stupid or....? (Scott Hart)
1 chris turn =360 degrees <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>thanks guys
You should be able to<B> completely</B> fill the gap up to the low beams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>p0cket penguins</b> »</i></TD></TR><TR><TD CLASS="quote">thanks guys when i get out of work ill try it out</TD></TR></TABLE><p>If you cannbot get the gap to fill... either:<p>1) your main beams are too high<br>2) did you tweak your bumper at all and fogs have been pulled low<p>
Re: am i stupid or....? (JimLill)
nope i just dont think that it does the correct amount of turns. ill check with a light. just so hard to fit my fat head under the fender
Discussion Starter · #13 ·
i took some pliers to it and it worked perfectly. so much better vision and much more sexy IMO<p><br>thanks everyone for the help
My fingers don't look sexy. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> They look like hamburger. Pliers are the way to go. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
1 - 14 of 14 Posts
