I installed my new PIAA yellow fogs yesterday, but ran into a problem. The drivers side bulb installation went fine; I turned on the lights after installing it and both came on. The passenger side was much more difficult to access but I was able to install the bulb correctly. When I went to turn the fogs on however, neither came on. The led in the dash switch was illuminated, but the fogs were dead. Is this just a fuse issue? I don't know why both would go out...I would think that only the affected light would be dead. The bulb packaging indicates 55W and from what I can tell the original bulbs were 35W. Can I just go to a bigger fuse if that is the problem? Thanks.
Evo
Evo
