1 - 6 of 6 Posts
Hi,
I was wondering if any of you had tried to mod your fog lights so that they turn on with the other lights? I plan on doing this because I like the look of fog lights but I hate having to think of turning them on.
I don't want to go to the stealer for a reflash or anything so I think i'll try and modify this either electronically or hardwiring it somehow.
Thanks
You could maybe somehow splice the wires and connect them to turn on with the low beams through that wire? I'm brainstorming here maybe someone with more wiring exp. then me will chime in
I could obviously do this and the best would be to use a relay to turn on a separate circuit to avoid having the fog in parallel with the low beams but I think I'll try and modify this electronically to retain the ability to use the switch to turn them off
Why not keep them separate? Is it really that foggy where you live? They can be quite blinding to oncoming traffic in the rain at night.
1 - 6 of 6 Posts
