Brand new Hella-Behr 65mm pan mounted oil cooler for RNC engines. 45% larger core volume and no plastic insulation jacket. This is the cooler used on the 5 cylinder Focus RS and BOLTS ON! This is a very important cooling upgrade for anybody who pushes their car on a regular basis. The stock cooler has enough thermal capacity for one full throttle pull before oil temps start to climb.
Larger oil cooler doesn’t mean your oil runs cooler. That’s not ideal anyway. With a larger water to oil cooler, engine oil will warm up faster and stay at regulated temperature longer.
Installation is simple. Drain coolant, unbolt/unclamp, catch a small amount of oil that will drain out, install new, refill coolant and top off oil.
$200 shipped.
131151
131152
131153
131154
Reactions: The Driver
Nice!
Automatic only?
2006 477 V70R 108k Miles
These are an excellent idea esp for those of you wanting to even improve day to day driving on your P1. Should have gotten one for my C30.
Sold
