Flywheel bolt and pressure plate torque specs
28K views 6 replies 5 participants last post by  bashhuey14
I discovered after installing my flywheel that several threads talked about using thread sealant to prevent an oil leak. Since I didn't do it I was little bit concerned, but I eventually found another thread that say it wasn't necessary when using new bolts (which I did). After 2000 miles no problem so far.
Also you should use a star pattern to tighten the bolts.
