A few days ago, a plastic ID card (like a credit card) slipped into the center console above the sliding door, indicated in my photo here. Does anyone have an idea of how to fish it out of there? Is there some panel I can easily remove to get in there, etc.?
You could try this thread for ideas. It's the XC60 forum though. For the XC90 I think the fabric sides of the console slide forward and then up.
https://forums.swedespeed.com/showt...x-among-other-documents&highlight=credit+card
also remember reading a thread and ran across access to the console. It reads like this:
2) Get access to your connection locations (Center Tunnel)
- Pry off the knee panel directly to the right of the driver's knees. The front-most panel not the aft-most panel, to be clear. You may need to move the driver's seat back a bit to get access. Only clips, no screws. Start towards the front and work your way back.
- Repeat this procedure for the passenger side panel on the other side of the center console.
Retreived from https://forums.swedespeed.com/showt...ent-Apps-etc&p=7223551&viewfull=1#post7223551
The side panels simply pull off. Try that to see if you can get it out. Otherwise it's alot more involved to pull the console and take it apart if needed.
