First Volvo questions 2012 xc70 T6 platinum 175K
4.7K views 22 replies 9 participants last post by  Oliverbutthead
Your brake fluid needs flushing. Your coolant ABSOLUTELY needs replacement. At Volvo of Toronto, each of those costs ~CAD125. Just stupid-cheap preventative maintenance, IMO.
Other highly useful tips from VolvoSweden is the AWD and diff servicing. Yuri gives you the part numbers, and you need a 250mm syringe, but take your time and it’s simple enough. I also installed the iPd rear diff module cover, as I live in the Salt Belt. Again, all cheap insurance.
I’d recommend against a transmission flush, but commence a series of drain and fills with Volvo-spec fluid. ~3.8l of ATF/service. I have the dealer do this because of the idiotic fill plug design.
Reactions: Brankovie
So brake system flush is recommended every 40k miles?
Brake fluid is hygroscopic. I change it every two years. Cheap preventative maintenance.
