thoughts?Hello,
My son just got a 2006 S60R, I drive a 1996 850R. We would love to get some maintenance thoughts from you guys. Also does anybody know anything about what type of transmission/ transaxle these cars have?
Thanks!
Sean
Beat me to my own post haha.If he has an automatic transmission, it's an Aisin AWF21 which is a 6spd. This is the more preferable of the two auto transmissions offered for S60Rs (AW55 offered for the 04-05 auto Rs). If it's a manual, it's a Getrag M66.
The AWD system uses an angle gear and collar sleeve for the rear drive.
Check this thread out. One of our members put together a pretty great excel maintenance log sheet.
http://forums.swedespeed.com/showthread.php?224368-100k-Maintenance-Template
More info on the car would help us let you know what to watch out for.Hello,
Thanks!
Sean
Stay stock K&N will kill your MAFThe car is an automatic.
We will be starting on the the stage 1 next weekend, He is in the Air Force so I will only be able to see it when he's home... lol
Any fluid recommendations? Spark plugs? Stock air filter Ok? or go with K&N?
Thanks for the responses!
Sean
No and Yes, A stock factory K&N will not destroy your MAF. An oiled K&N will, personally I've had K&N in all my cars and never had a problem, that said I clean the filters regularly and don't oil them. I've never had a problem, just clean them and your fine. Use APC on a cloth and wipe it off, then blow out the deep slats with a leaf blower or if you can compressed air. This works wonders.Stay stock K&N will kill your MAF
There is no difference with K&N and stock in airflow at all just so you know. If you want to hear the turbo get a nice DP![]()
I have the same, TF80SC is your trans aka 6 speed GT.The car is an automatic.
Sean
Feel free to PM me if you need help. I've done all the basics on my 06 GT. I bought mine with 53K and have 83 now, done almost everything myself.I have read thru quite a few of the stickys... there is too much info there.
Asking the questions you need answers too saves time... and is a great way to connect with folks who like to share info.
That's the biggest reason I joined. I lurked for over a year and finally got fed up with "look it up" and "search!" type comments. Like I said in my first post, this is an online forum, not a library. You don't come here to go through indexes and find info. If that was the case, pretty much no new threads should be made.I have read thru quite a few of the stickys... there is too much info there.
Look at all the threads that you've started that you could have LOOKED UP. Things like the cost of a new key, drain and fill vs flush, etc... How would you feel if all you were told was to look it up?This is all in the stickys at the top of the R forum that all new members should read through because there is tons of extremely helpful write ups written by members, and it also helps to eliminate threads like this one.
