1 - 20 of 55 Posts
have 1500 miles on my R. was going to change out factory oil and start synthetic. any opinions? thanks
I was told by one of my mechanics to wait until at least 10,000 miles on it to start synthetic and he specifically stated that the R needed to wait longer than other Volvos. I know others may disagree but just passing on what I was told, but this guy seemed very informed about the R's which has not been the norm for me.
Re: first oil change (row)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">have 1500 miles on my R. was going to change out factory oil and start synthetic. any opinions? thanks</TD></TR></TABLE><p>I ran the initial fill to around 2000; used Syntec Blend 10/30 for another 2000 and then went Mobil 1 10/30 around 4000. I split the recommended interval to 3750 with M1 from there.
Re: first oil change (defgh1)
thanks doug, mobil 1, 5w 30 or 10w 30? live in northeast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">have 1500 miles on my R. was going to change out factory oil and start synthetic. any opinions? thanks</TD></TR></TABLE><p>Hey row,<p>Check this resent thread, see the comments by RearWheelPaul and Pat S. <A HREF="http://forums.swedespeed.com/zerothread?id=61488" TARGET="_blank">OilInfoThread</A><p>LTA
Re: first oil change (LTA)
Thanks LTA, great stuff! does not seem like it matters much 5w or 10w 30 oil. also, do folks have a prefered oil brand? thanks again, swedespeed rocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">Thanks LTA, great stuff! does not seem like it matters much 5w or 10w 30 oil. also, do folks have a prefered oil brand? thanks again, swedespeed rocks.</TD></TR></TABLE><p>5W30 or 10W30 depends on the temperature where you live, check the owner's manual and you'll find this chart:<br><IMG SRC="http://new.volvocars.com/ownersdocs/2006/2006_S60/images/pg171a.jpg" BORDER="0"><br>This is a link to the full manual:<br><A HREF="http://new.volvocars.com/ownersdocs/2006/2006_S60/06s60_00.htm" TARGET="_blank">http://new.volvocars.com/owner...0.htm</A><p>Most argree that the really wide-range oils, like 0W40 or 5W40, are <B>not</B> the way to go.<p>LTA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LTA</b> »</i></TD></TR><TR><TD CLASS="quote">5W30 or 10W30 depends on the temperature where you live, check the owner's manual and you'll find this chart:<br><IMG SRC="http://new.volvocars.com/ownersdocs/2006/2006_S60/images/pg171a.jpg" BORDER="0"><br>This is a link to the full manual:<br><A HREF="http://new.volvocars.com/ownersdocs/2006/2006_S60/06s60_00.htm" TARGET="_blank">http://new.volvocars.com/owner...0.htm</A><p>Most argree that the really wide-range oils, like 0W40 or 5W40, are <B>not</B> the way to go.<p>LTA</TD></TR></TABLE><p>Definitely agree with the above. The wider range oils have more additives that tend to break down faster than a narrower range oil.<p>I use 10/30 Mobil 1 year round. It's a rare occasion that temps fall below -4F and even if they did, M1 pours to somewhere around -40F so not much worry IMO. We're more apt to break the 86F threshold of 5/30.
Banned
Re: first oil change (MagoonR)
I'm with you on 10W30, MagoonR. 5W30 is just a bit too thin for a turbo motor in the summer. Better film strength and higher oil pressure in stop-and-go traffic with a 10W30.
Doug, any thoughts on the 10W-30 comments below vs. 5W-30? thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">Doug, any thoughts on the 10W-30 comments below vs. 5W-30? thx</TD></TR></TABLE><p>It's really simple if you RTFM <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"><p>Here's a quote from <A HREF="http://new.volvocars.com/ownersdocs/2006/2006_S60/06s60_11a.htm#pg142" TARGET="_blank">page142</A><br>"Operation in temperate climates<br>Incorrect viscosity oil can shorten engine life. Under normal use when temperatures do not exceed 86° F (30° C), SAE 5W/30 will provide good fuel economy and engine protection. See the viscosity chart.<p>Extreme engine operation<br>Synthetic oils meeting SAE 10W/30 and complying with oil quality requirements are recommended for driving in areas of sustained temperature extremes (hot or cold), when towing a trailer over long distances, and for prolonged driving in mountainous areas."<p>
So what's the consensus on after the first few oil changes? Can the R go safely for 7500 miles (as recommended in the manual) on a good fully synthetic oil? I plan to use M1 10W-30 at my first change soon...I've got about 1800 miles on my car now. Then I'll get the free 7500 mile service on volvo's dime and change oil again. But then I would plan to use M1 10W-30 extended life (or something like that) every 7500 miles.
Re: first oil change (soledoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>soledoc</b> »</i></TD></TR><TR><TD CLASS="quote">So what's the consensus on after the first few oil changes? Can the R go safely for 7500 miles (as recommended in the manual) on a good fully synthetic oil?</TD></TR></TABLE><p>It probably can but most of us choose to go shorter. After all, good oil is a high heat turbo's best friend.
So my question is that what benefits do you get by changing the oil more frequently after the first few changes than what's recommended by the manual?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>soledoc</b> »</i></TD></TR><TR><TD CLASS="quote">So my question is that what benefits do you get by changing the oil more frequently after the first few changes than what's recommended by the manual?</TD></TR></TABLE><p>you are keeping the engine even cleaner than what volvo recommends <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: first oil change (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">you are keeping the engine even cleaner than what volvo recommends <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"></TD></TR></TABLE><p>Volvo is in the business of selling cars. Therefore, they will recommend a minimum service requirement which may or may not be the best thing for the longevity of the vehicle but will get you through the warranty period.<p>Oil breaks down over time though less so with the synthetics. Therefore, it is not a good idea to push drain intervals beyond a reasonable period. Depending on who you ask, that period is subjective of course. In my case, every 3750 miles is about 6 months so that is my comfort zone. IMO, a few extra bucks to provide added protection is worth it. You may think that it's throwing away $$$$ but I am sure that the next owner will appreciate my care.<p>On a side note, do you really believe that BMW 15,000 mile intervals make sense; especially on the initial factory fill? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
i just hit 3,000 miles this past weekend so I will be doing my first oil change on saturday, woohoo!<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>On a side note, do you really believe that BMW 15,000 mile intervals make sense; especially on the initial factory fill? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> </TD></TR></TABLE><p>Or how about 20K miles on my wife's Cayenne!
1 - 20 of 55 Posts
