My wife gave a little love tap to a low metal trailer and worked her front fender pretty good
It looks like at least 2 pieces are damaged, luckily the sensors still seem to work
Will a bodyshop be able to correct this without a whole new bumper?
It’s pretty small but I imagine the plastic just has to be replaced at worst
https://imgur.com/a/Gu41AJm
It looks like the paint above the crease was damaged, so they would have to sand and repaint that area. Not sure you can re-bend the one lower piece. You may need to replace. Keep us informed.
From the picture, it appears to be deformation that can be repaired with some heat application. The side "vent" is also partially popped out. If you pull that piece out, you can see if there is any additional damage
Yeah the paint looks cracked where it creased. I’m hoping the whole bumper doesn’t have to be replaced.
Thanks for the replies thus far
