1 - 9 of 9 Posts
I am considering selling this car, silver on black, with all the maintenance done, in the Boston, MA area.
I will post pictures in the next few days.
The mainatenace done is the following:
AC compressor (4 Seasons rebuild)
AC dryer
Water pump
All timing pulleys (Volvo)
Timing belt (Volvo)
All accessory pulleys (Volvo)
Accessory belt
Accessory belt tensioner (Volvo)
Fuel filter
Air filter
Spark plugs (Volvo)
Gearbox lever brass
Front O2 sensor (Bosch)
Rear O2 sensor (Bosch)
Cooling system flush
Thermostat (Volvo)
Temperature sensor (Volvo)
Cabin filter
CV boots (both) GKN Lobro
transmission oil flush (Volvo)
struts OEM (Sachs)
spring seats (Volvo)
strut mounts + nuts (Volvo)
axle nuts 36mm (Volvo)
R springs
rear shocks OEM (Sachs)
driver's door lock (Volvo)
driver's door lock actuator (Volvo)
Parking brake cables (Volvo)
Parking brake pads (Volvo)
Tailgate lock actuator
Breather box + hoses + clamps (Volvo)
Vacuum lines (Volvo)
Servo vacuum hose (Volvo)
aug 12 rear caliper passenger side
new pads rear Volvo
new rotors rear Volvo
sep 12 new MAF
160000 nov 12 replaced ABS module (repaired)
162400 mar 13 outer & inner tie rod (Lemfoerder)
162900 jul 13 delta end links (Lemfoerder)
4 new tires (Conti DWS)
4 wheel alignment (Hogan tire - westwood)
163100 sep 13 turbo, rebuild
R manifold
DP
water hoses to turbo
oct 3 Eurosport Tunning exhaust
165000 14 Sep 2014 radiator upper hose
02 Dec 2014 radiator & lower hose replacement @ Boston Volvo
jun 2015 Alignment (Boston Volvo)
https://onedrive.live.com/redir?resid=4CCEC51A455E920!542&authkey=!AKW6IMr3C_7vu-k&v=3&ithint=photo%2cpng
https://onedrive.live.com/redir?res...authkey=!ADpw5uqEXcsxOGM&v=3&ithint=photo,png
https://onedrive.live.com/redir?res...authkey=!APQVVN20hwOi09I&v=3&ithint=photo,png
Price is $5000.-
PS: Correction mileage is 167k
2004 S60R 6M - 2006 V70R 6M - 2014 XC60 R-Design OSD - 2015.5 XC70 T6 Platinum
Looks good! I've said it before and I'll say it again, IF I could I would. Such a unique car, GLWS. FYI My birthday is next week, if you're feeling generous this would be the coolest gift...ever.. ;)
1 - 9 of 9 Posts
