1 - 11 of 11 Posts
Hi guys,
Any of you around the globe with a Drive-E T5 engine with engine code B4204T11, have done the Polestar Optimization to 253 hp / 400 Nm ?
Not looking at the figures which looks insignificant on the horses, any feedback on the driving dynamics/response? Have heard from the Dealer that they tried the *Test Car* and the Mid-High Range has improved tremendously as there is more Pull. Will be anyone be able to verify this?
Am from Singapore, and dealer are still working out Documents to clear through with the authority before it can be officially launched.
Lancert, seems you're not in the US - where are you located? I wasn't aware the gasoline powered T5 Drive-E had a Polestar tune available yet.
It is not, yet, available in the U.S.
Then what the heck was the list below that I found on the polestar website just a few days ago?
Below is a post I made in a different thread. Note, using my own instructions below, this list no longer appears. Was this a technical glitch on the part of Polestar's website?
They have a glitch in their site. DON'T click on the pictures. You have to select "or choose your model". Select your vehicle, it then takes you to a list of all the supported engine configurations for that model.
For example, my T5 Drive-E XC60 can get polestar. Below is the list I see when I select the XC60 from the drop down. I can select each of them and it brings me to the specifics of that vehicle.
Engine Transmission Year Original Polestar Engine Denomination Engine Code SP
2,0T Automatic FWD 2010 203 hp / 300 Nm 240 hp / 320 Nm B4204T6 44 31342664
2,0T Automatic FWD 2011 203 hp / 300 Nm 240 hp / 320 Nm B4204T6 44 31342664
2,4D Automatic AWD 2009 163 hp / 340 Nm 185 hp / 400 Nm D5244T5 69 31312704
2,4D Automatic AWD 2009 163 hp / 340 Nm 205 hp / 450 Nm D5244T5++ 69 31312705
2,4D Automatic AWD 2010 163 hp / 420 Nm 225 hp / 460 Nm D5244T16+ 80 31312757
2,4D Automatic AWD 2010 163 hp / 420 Nm 205 hp / 420 Nm D5244T16 80 31312756
2,4D Manual 6-gear AWD 2009 163 hp / 340 Nm 185 hp / 400 Nm D5244T5 69 31312704
2,4D Manual 6-gear AWD 2009 163 hp / 340 Nm 205 hp / 450 Nm D5244T5++ 69 31312705
2,4D Manual 6-gear AWD 2010 163 hp / 420 Nm 225 hp / 460 Nm D5244T16+ 80 31312757
2,4D Manual 6-gear AWD 2010 163 hp / 420 Nm 205 hp / 420 Nm D5244T16 80 31312756
2,4D Automatic FWD 2010 175 hp / 420 Nm 195 hp / 460 Nm D5244T14 72 31312755
2,4D Manual 6-gear FWD 2010 175 hp / 420 Nm 195 hp / 460 Nm D5244T14 72 31312755
D3 Automatic AWD 2011 163 hp / 420 Nm 225 hp / 460 Nm D5244T16+ 80 31312757
D3 Automatic AWD 2011 163 hp / 420 Nm 205 hp / 420 Nm D5244T16 80 31312756
D3 Automatic AWD 2012 163 hp / 420 Nm 215 hp / 440 Nm D5244T17_A 87 31342963
D3 Automatic AWD 2012 163 hp / 420 Nm 200 hp / 440 Nm D5244T17_A 87 31452012
D3 Manual 6-gear AWD 2011 163 hp / 420 Nm 225 hp / 460 Nm D5244T16+ 80 31312757
D3 Manual 6-gear AWD 2011 163 hp / 420 Nm 205 hp / 420 Nm D5244T16 80 31312756
D3 Manual 6-gear AWD 2012 163 hp / 420 Nm 215 hp / 420 Nm D5244T17_M 87 31342963
D3 Manual 6-gear AWD 2012 163 hp / 420 Nm 200 hp / 420 Nm D5244T17_M 87 31452012
D3 Automatic FWD 2013 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D3 Automatic FWD 2014 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D3 Automatic FWD 2015 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D3 Manual 6-gear FWD 2013 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D3 Manual 6-gear FWD 2014 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D3 Manual 6-gear FWD 2015 136 hp / 350 Nm 163 hp / 400 Nm D5204T7 31 31432183
D4 Automatic AWD 2013 163 hp / 420 Nm 215 hp / 440 Nm D5244T17_A 87 31342963
D4 Automatic AWD 2013 163 hp / 420 Nm 200 hp / 440 Nm D5244T17_A 87 31452012
D4 Automatic AWD 2014, 163HP (original) 163 hp / 420 Nm 215 hp / 440 Nm D5244T17_A 87 31342963
D4 Automatic AWD 2014, 163HP (original) 163 hp / 420 Nm 200 hp / 440 Nm D5244T17_A 87 31452012
D4 Automatic AWD 2014, 181HP (original) 181 hp / 420 Nm 215 hp / 440 Nm D5244T12_A 81 31432181
D4 Automatic AWD 2015 181 hp / 420 Nm 215 hp / 440 Nm D5244T12_A 81 31432181
D4 Manual 6-gear AWD 2013 163 hp / 420 Nm 215 hp / 420 Nm D5244T17_M 87 31342963
D4 Manual 6-gear AWD 2013 163 hp / 420 Nm 200 hp / 420 Nm D5244T17_M 87 31452012
D4 Manual 6-gear AWD 2014, 163HP (original) 163 hp / 420 Nm 215 hp / 420 Nm D5244T17_M 87 31342963
D4 Manual 6-gear AWD 2014, 163HP (original) 163 hp / 420 Nm 200 hp / 420 Nm D5244T17_M 87 31452012
D4 Manual 6-gear AWD 2014, 181HP (original) 181 hp / 420 Nm 215 hp / 420 Nm D5244T12_M 81 31432181
D4 Manual 6-gear AWD 2015 181 hp / 420 Nm 215 hp / 420 Nm D5244T12_M 81 31432181
D4 Drive-E Automatic FWD 2014 181 hp / 400 Nm 200 hp / 440 Nm D4204T5 73 31452795
D4 Drive-E Automatic FWD 2015 181 hp / 400 Nm 200 hp / 440 Nm D4204T5 73 31452795
D4 Drive-E Automatic FWD 2016 190 hp / 400 Nm 200 hp / 440 Nm D4204T14 A8 31478103
D4 Drive-E Manual 6-gear FWD 2014 181 hp / 400 Nm 200 hp / 440 Nm D4204T5 73 31452795
D4 Drive-E Manual 6-gear FWD 2015 181 hp / 400 Nm 200 hp / 440 Nm D4204T5 73 31452795
D4 Drive-E Manual 6-gear FWD 2016 190 hp / 400 Nm 200 hp / 440 Nm D4204T14 A8 31478103
D5 Automatic AWD 2009 185 hp / 400 Nm 205 hp / 450 Nm D5244T4 71 31312703
D5 Automatic AWD 2010 205 hp / 420 Nm 225 hp / 460 Nm D5244T10 70 31312754
D5 Automatic AWD 2011 205 hp / 420 Nm 225 hp / 460 Nm D5244T10 70 31312754
D5 Automatic AWD 2012 215 hp / 440 Nm 230 hp / 470 Nm D5244T15 82 31342962
D5 Automatic AWD 2013 215 hp / 440 Nm 230 hp / 470 Nm D5244T15 82 31342962
D5 Automatic AWD 2014 215 hp / 440 Nm 230 hp / 470 Nm D5244T15 82 31342962
D5 Automatic AWD 2015 215 hp / 440 Nm 230 hp / 470 Nm D5244T15 82 31342962
D5 Automatic AWD 2016 220 hp / 440 Nm 230 hp / 470 Nm D5244T20 97 31452784
D5 Manual 6-gear AWD 2009 185 hp / 400 Nm 205 hp / 450 Nm D5244T4 71 31312703
D5 Manual 6-gear AWD 2010 205 hp / 420 Nm 225 hp / 460 Nm D5244T10 70 31312754
D5 Manual 6-gear AWD 2011 205 hp / 420 Nm 225 hp / 460 Nm D5244T10 70 31312754
D5 Manual 6-gear AWD 2012 215 hp / 420 Nm 230 hp / 470 Nm D5244T11 83 31342961
D5 Manual 6-gear AWD 2013 215 hp / 420 Nm 230 hp / 470 Nm D5244T11 83 31342961
D5 Manual 6-gear AWD 2014 215 hp / 420 Nm 230 hp / 470 Nm D5244T11 83 31342961
D5 Manual 6-gear AWD 2015 215 hp / 420 Nm 230 hp / 470 Nm D5244T11 83 31342961
D5 Manual 6-gear AWD 2016 220 hp / 420 Nm 230 hp / 470 Nm D5244T22 AJ 31452786
T5 Drive-E Automatic FWD 2014 245 hp / 350 Nm 253 hp / 400 Nm B4204T11 40 31459463
T5 Drive-E Automatic FWD 2015 245 hp / 350 Nm 253 hp / 400 Nm B4204T11 40 31459463
T5 Automatic FWD 2014 220 hp / 350 Nm 245 hp / 350 Nm B4204T15 AG 31441203
T5 Automatic FWD 2015 220 hp / 350 Nm 245 hp / 350 Nm B4204T15 AG 31441203
T6 Automatic AWD 2009 285 hp / 400 Nm 315 hp / 480 Nm B6304T2 99 31380334
T6 Automatic AWD 2010 285 hp / 400 Nm 315 hp / 480 Nm B6304T2 99 31380334
T6 Automatic AWD 2011 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Automatic AWD 2012 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Automatic AWD 2013 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Automatic AWD 2014 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Automatic AWD 2015 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Automatic AWD 2016 304 hp / 440 Nm 329 hp / 480 Nm B6304T4 90 31342701
T6 Drive-E Automatic FWD 2015 306 hp / 400 Nm 310 hp / 430 Nm B4204T9 49 31459465
T6 Drive-E Automatic FWD 2016 306 hp / 400 Nm 310 hp / 430 Nm B4204T9 49 31459465
This info must be from the global site, not for the U.S.
I am from Singapore, and in the polestar website, theres a option for you to key in your VIN number to check specifically which optimization for solely for your beloved ride!
Here in Australia the Polestar optimisations have been available for the Drive-E T5 (and D4 diesel) for 2-3 months now. Not aware from the various forums about anyone getting for the S60 or V60 T5s. However there a number who have had the Polestar tune done to their V40 T5 and V40CC T5 AWD. The overall net impact is not that impressive - for the V40 T5s the 0-100km/h (0-62mph) is reduced by only 0.1 sec. However they reported back that as per the PR blurb about these tunes the real benefit is in the mid-range particularly for overtaking. Here in Australia they are expensive (~AU$1,250) but a few have managed to negotiate on this price as part of the car purchase.
I appreciate many may say its unrelated to the Drive-E T5, but one guy did some before and after timing tests on a V40 Drive-E D4. I wont bore you with the details but the two main results of the test were :-
1. pretty much confirmed the net improvement in the 0-62 mph sprint was about 0.1 sec.
2. there was a 10%-15% improvement in the 40mph to 70mph rolling acceleration time - very useful for overtaking.
As I say might not be directly applicable to the Drive-E T5 but it does give a feel for what the Polestar tunes will do for the Drive-E engines.
Tony
thank you for your input bro,
to be frank and objective, actually its not about the century sprint timing mainly as we dont do it all the time, but its more on the power in the mid range when overtaking plays a huge part of driving.
Tony
Do we know for sure whether or not the transmission has to be in Sport for the tune to have an effect?
nope, confirmed with the dealer who tested the car, even in normal mode the effect can be felt for the tune, that was my initial worry too, if only sports mode can feel the tune, I will give this tune a miss
1 - 11 of 11 Posts
