Yesterday I started getting a bulb out warning from using the turn signals which would go away when the brakes were depressed. I did a visual check and the turn signals and brake lights all work properly. Is there an obvious culprit here, or do I get to chase down an electrical gremlin (something I think I've stated before that I'm not particularly gifted at)?<p>cheers,<br>scott
Re: False bulb out warning? (scootergeek)
Easy fix.<p>Check all tail light bulb sockets, wires and grounds for cleanliness and continuity. Be sure bulb-type applications are identical on both sides of the car.<p>George Dill.<p>
