1 - 12 of 12 Posts
I have the Orange Electronics TPMS which monitors all 4 tires press/temp simultaneously. I had an issue where my one tire had a serration and was leaking quite nicely (even with plugs), but a couple months ago, I put a patch on the inside and it finally stopped. The tire in question usually rides at 39-40psi when warm, so when I leave work today and get on the highway, I am shocked to see 45psi for that tire.
Now this Orange Electronics TPMS is something that I wouldn't buy again, probably. Sometimes it doesn't get the readings right away and can take up to 30 minutes for any one of the tires to read, but this only happens 10% of the time. I thought maybe the data transfer from the sensor to the receiver was screwy, so I checked the pressure when I got home and sure enough, it was 45.
All other tires read their normal values.
The only explanation is that someone put air in my tire, lol.
Re: Falken's self-inflating tires! (phuz)
you caught me
Banned
an other mistake tire-manufactures are trying, before ....
run on flat tires are just crap ... they bend rims, they can't be repaired, have no comfort. lot's of owners wanted normal tires afterwards/during their ownership (i worked for bmw who had/has rft-tires standard across the entire segment).
Re: Falken's self-inflating tires! (JoeLvo)
Quote, originally posted by JoeLvo »
whoa, check them again, they may be at 50psi (I didnt know anyone ELSE was secretly adding air to your tires)...
If you don't mind, next time hit the other 3, too
Quote, originally posted by phuz »
You got it. My plan is to add 6 psi in DF, 12psi in PF, 3 psi in DR, and 22 psi in PR. Sound good? Wait, too late. bing, your clown-car tires are ready...
Conspiracy theories aside, my mind goes to heat, as in this tire is heating up more than the others during normal driving (PV=nRT and all). Might be time to do some detective work with that in mind.
1 - 12 of 12 Posts
