About month ago the girlfriend was driving home on a Friday night and had #4 coil pack fail. I wasn't too surprised as the XC90 (146K miles) was due for a new set and new plugs but a pain none the less. Needing all the cars on the road for the week (two teens driving and the GF in nursing school) my only option was aftermarket coils, either DuraLast or Import Direct from O'Reilly.
I went with the Import Direct after reading on here they might be reboxed Volvo oem, unfortunately they are not. Went with Bosch Iridium plugs since that's all I could get over the weekend to have the car on the road monday morning.
Install went fine, I had to replace the fuse as well, no errors to speak of and the car drives great. Then a day later I get the CEL and dreaded P0420 and P0430 catalyst codes. I read through a million threads on the error so I am starting basic -> to $$ repairs. I cleaned the MAF, did a PCV glove test, checked for vacuum leaks, cleared the codes once, drove 45+ minutes on the highway to hopefully burn anything in the cat out and just cleared the codes again today. Oil change and new air filter a week or two before the coil pack went, I've been running full Castrol synthetic since I bought the car 5 years ago.
I'm adding some Jectron to the tank today and we'll see if the codes stay cleared.
Questions:
Would the Bosch plugs throw this error code? I was under the impression that the Bosch Iridiums would be fine, although I do know how finicky Volvos can be about plugs.
I am about to order a new thermostat and PCV as maintenance items, anything aftermarket OK for this or stick with genuine Volvo? Dorman PCV is less than half the cost but I can't find any Volvo specific reviews, not sure about what aftermarket T stat would last (Mahle, rein?).
Is there a good way to test the upstream o2 sensors? I have VIDA and a dice unit but just starting to get acquainted with it.
Will aftermarket o2 sensors function or am I biting the bullet and spending $260+ on each one?
Questions:
