my turbo boost guage at full throttle barely goes into the white. ive checked the vac lines and they look good. the turbo sounds good. <p>anyone having a stock 850 turbo how far does there guage go over?<p> i was told to turn the wastegate rod but i dont wanna over do it.....thanks for any help with this...
The factory boost gauge is finnicky at best. They are all different, even on the same model car. My suggestion is to install an after market one that gives you true readings.
Re: fac. boost guage question (phils94850)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phils94850</b> »</i></TD></TR><TR><TD CLASS="quote">my turbo boost guage at full throttle barely goes into the white. ive checked the vac lines and they look good. the turbo sounds good. <p> </TD></TR></TABLE><br>Could be OK. Mine went just a bit into the white (unitl I installed a chip) then it "PEGGED" the gauge <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
jrl.. where did you get the chip ? i had a mazda mx6 turbo and all you had to do was remove the ecu and solder in the new chip. it made a heck of a difference on the car.<p>is it the same on our volvo's ?
Re: (phils94850)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phils94850</b> »</i></TD></TR><TR><TD CLASS="quote">jrl.. where did you get the chip ? i had a mazda mx6 turbo and all you had to do was remove the ecu and solder in the new chip. it made a heck of a difference on the car.<p>is it the same on our volvo's ?</TD></TR></TABLE><br>No, not exactly, you send the ECU out to get flashed or you buy one core exchange.<br>Plenty around, ipd, bsr, upsolute. Ask on Volvospeed who their ECU flavor of the month is. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>The ECU I swapped was one out of an old R I bought and sold, it was a PEC unit, they don't make them anymore but it seems to be as good as others I've had. Installed a regular boost gauge last week, twisted the wastegate a couple of turns and in this heat it's running a steady 16 lbs, good early on boost with spikes to 18 or so.<br>Should be good for another pound or two in colder weather <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (phils94850)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phils94850</b> »</i></TD></TR><TR><TD CLASS="quote">i had a mazda mx6 turbo and all you had to do was remove the ecu and solder in the new chip.</TD></TR></TABLE><p>that is one method.<p>the other method is the flash. ipd/tme is the only one that does this, afaik.<p>all the other chips have soldered stuff on the ecu.<p>if all ur vacuum hoses look fine, i'd check ur turbo/ic rubber hoses. there are five pieces. one from turbo to the pipe that runs over ur engine. one from that pipe to another pipe. this second pipe to the ic. the ic to a third pipe (up top). and finally, the third pipe to the throttle body. 5 total<p>here's a pic<br><IMG SRC="http://www.samcosport.com/images/large/TCS53.jpg" BORDER="0">
Re: (steve s)
wait. u have a 94 turbo?<p>if that's the case, then the above pic is useless for u.<p>u need the reverse intercooler piping, but u get the idea. those rubber pipes tend to go after 10 yrs <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
