Re: Extended Bolt Question (lowenhart)
Not for nothing, I thought that 5mm spacers didn't require different/extended bots...
Quote, originally posted by JoshV70_ » |
I would definitely recommend longer bolts with 5mm spacers...unless of course you want your wheel to fall off. |
Quote, originally posted by rushin_max » |
Metric Grade 10.9 bolts Alloy Steel, Quenched and Tempered Proof Load----830 (MPa) Min. Yield Strength--940(MPa) Min. Tensile Strength---1040(MPa) source: http://www.boltdepot.com/faste....aspx |
Quote, originally posted by xman03 » |
Are they 17mm heads versus the stock 19mm? They look like the ones I got from IPD for the 15mm spacers. |
Quote, originally posted by lowenhart » |
Is this good for my application? Sorry, I am clueless when it comes to this. I torqued them down to 100lbs Any one know where these bolts originate from? Thanks Henry |
