I'm gonna start this here so it doesn't clog up the Smartphone Shot of the Day thread. If the mod wants to migrate those conversations here, that would be cool, but not necessary
So I've seen some WRX's and other Japanese turbo cars with their charge pipes wrapped in heat wrap or with a reflective engine tape. I thought I would take the plunge and give it a try.
When I posted the pics of my finished product it started quite a hubbub in the SPSotD thread, and nothing ever quite got resolved. So I'm going to post my findings as they appear.
My personal theory on this is: At start up, the wrapped CAP will keep heat in the pipe that would normally escape, bringing cold engine efficiency down slightly
. Once the engine is up to temp and under normal driving conditions, the CAP temps will remain 3-5 degrees cooler as it enters the intercooler. Under hard/racing conditions when engine temps are their hottest, I could see wrapped CAP temps being slightly more insulated from the even hotter engine bay. These temp differences, if present, could slightly improve intake temps and/or gas mileage.
The basic idea is to keep the hot air in the charge pipe from getting hotter from the engine block/bay heat as it goes up and over to the intercooler, theoretically giving the intercooler a little less work to do. A thread on another site claims a 3-4 degree drop in intake temps from wrapping the CAP on a turbo Prelude, but no graphs or before/after numbers are posted: http://www.preludepower.com/forums/archive/index.php/t-284970.html
There are questions I have that hopefully someone can answer though!
1. What is the average under hood temp when driving at highway speeds?
2. What is the average charge air temp in the pipe at highway speeds?
3. What are the symptoms of early detonation, which can be a sign of intake temps being too hot? I'd like to know what they are just in case this happens to cause them.
Until questions 1 and 2 are answered, I'm kind of doing this blind. I'm not sure there are even good ways to measure those
Since this was day 1 of the experiment, I really don't have any results yet. The heat wrap I used was this: http://prosportgauges.com/fiberglass-header-wrap-1-1.aspx
Current avg. mpg is 19.8. We'll see if it stays relatively the same, degrades, or improves with the wrap under my normal driving habits.
As stated before, I have no idea if this will do nothing, make things worse, or make an improvement. This is not the mother of all forgotten mods or anything, but I think it could make a *slight* improvement, although at the expense of having a fuzzy CAP, which isn't the most attractive under-the-hood accessory
I was tempted to grab the blue wrap they offer, but figured I'd go ceramic versus colored fiberglass.
Anyways, I'm kind of interested to see how this comes out, no matter the outcome.
