521 - 540 of 563 Posts
Discussion Starter · #521 ·
On the way to work today, I grew impatient behind a dump truck. So, full boost boogie time! WAAAAAA...POOF! Limp mode. Fudge! Pop the hood and have a look. Blew the OTE pipe out of the turbo coupler. Fortunately, I threw the tool bag in the car. Put it back together and cranked on the clamp.
Earlier in the day, I topped off the coolant and drained a few ounces of transmission fluid by removing the spin on filter. Perfect! When I got home the level was at the max hot line.
Sent from my SM-G950U using Tapatalk
Reactions: Antherzoll
Hahaha boost
Discussion Starter · #525 ·
Partially? I needed a 30 deg coupler with a 2" outlet. All I had was a silicone one with 2.5" outlet. So, I slid my old 2" rubber coupler into it. A little shade tree, but works if you clamp it tight enough. It's only temporary until my new coupler gets here this week.
40% higher capacity for not a huge amount of money
If the link goes to a no longer available notice just search the part number indicated
Ok, thanks. Quite sure what I've ordered is the same size just used for $50 CAD shipped. The number of plate stacks count the same as the one in the image, unless I'm missing something.
Discussion Starter · #530 ·
The 8677973 is the 15 plate D5 cooler. Is there another difference?
I had to search through quite a few eBay listings for the best deal. It looks like 8677973 is also posted for a cooler that is the same size as the original but for diesel. What looks like the correct PN for the larger cooler is Volvo 31201912, but for some reason still gets listed as 8677973 by sellers on eBay.
Other PNs I found for Volvo 31201912 are:
Hella 8MO 376 751-791
C5850003
Discussion Starter · #532 · (Edited)
C5850003
Ahh, Volvo part number confusion (and add in some eBay chaos too)! I spent a lot of time tracking them down a few months ago. I believe that the 31201912 is still 15 plates. Maybe it superseded 8677973 (or maybe the other way around)? Mine also has the Behr C5850 number on it, along with the Volvo 8677973.
Yes, I assume it's still set for halogen. Can that be changed with VIDA?
No, but you can with Vdash
Sent from my Pixel 5 using Tapatalk
Did some xenon headlight issue debugging. When I turn on the lights with the engine not running, or start the engine with the lights on, the CEM shuts off the right headlight. Swapped CANBUS adapters. No change. Swapped ballasts. No change. Just have to live with it, I guess.
Bumper cover back on and under engine shield back on. Topped off the transmission fluid. Test drive time. Take it easy through the neighborhoods. No issues. Hit the main road and the low coolant warning starts flickering. Great. Make a beeline for home. Back into the garage. Pop the hood and grab a light. No obvious leaks. Thermostat must of popped fully open. Top that off in the morning. Checked the transmission fluid. A bit high. I'll have to draw out a couple of ounces once tomorrow.
Wife's car is back in the garage. She'll be happy!
Which Canbus adapters did you use?
Discussion Starter · #535 ·
Th
The ones from TRS. Once the lights are on, I'm good. It's the lower voltage start up conditions causing the problem.
Th
I think I got same issue. Tried installing HIDs in place of halogens using OEM ballasts and headlights turn on for a second then turn right back off.
Discussion Starter · #537 ·
I'm wondering if a relay would fix the problem? Run through the CANBUS adapters to a relay. The relay would be connected to power. That way, any initial current surge to ignite the lights isn't seen by the CEM.
Discussion Starter · #538 ·
Purty! Got some T-Bolt clamps to go with it.
Reactions: tabormeister
I had to buy a brand new OTE pipe after silicone hose and t-bolt clamp. Could not stop the air leak.
Discussion Starter · #540 ·
Did you crack it?
