1 - 12 of 12 Posts
I'm thinking about getting the PPC tune which would give me about 230=40 hp with stock dp and exhaust.. i decided to keep my dp and exhaust stock.. but thought about cutting the stock muffler out and putting a magna flow for a nice exhaust note (just for sound).. anyone 's done this ? i couldnt see how this would cause any problems... suggestions welcomed...
Re: Exhaust Question. (deerok)
I actually thought about doing this on my R then went ahead and ordered the whole system anyways... You would get more than sound if you found a competent fabrication shop to remove the factory mufflers and weld in quality performance units... I think it would be great... as far as causing any problems... If you are only messing with the cat back and the welds on the exaust are good then I don't see any... http://********************/smile/emthup.gif
the stock system features one 2.25" pipe.
at the least i'd find a local R owner and snag their stock exhaust...
Re: (Impulse922)
If you want to keep in touch I will send you mine off my 06 with 30K for $100.00 plus shipping from WA area though I won't be to the states until end of June begining of July. It will be in three sections one cut between the res and Y split and one cut on the dual pipes at the end of the straight. Let me know. Plus I know the R exhaust would be an upgrade in itself and if you did the JRL mod... (removing the resonator it might be exactly what you are looking for. http://********************/smile/emthup.gif
Re: (kmg_S60R)
Be careful just throwing a different muffler in there. Obviously you are looking for a cheap solution to add sound. I don't know much about the exhausts on these cars, but I think a Magnaflow sounded good when I heard a clip.
Re: (Tiny)
thats exactly what i wanted to go with (magna Flow) ...yea Kmg let me know what's up when you get back i might take that off your hands and go that route.. I'm in no hurry to get it done.
Re: (deerok)
I will get in touch with you when I get back.
its going to be difficult to get a muffler that will work correct.. ever seen the goofy shape of the stocker?
1 - 12 of 12 Posts
