Hello Folks,
Last year my 2012 S60 T5 developed a bit of a whistling noise when starting up cold which lessened as the car reached temp. The whistling got louder as time went on until there was a noticeable exhaust tick. I put two and two together and figured it was loose exhaust stud nuts. It took me about an hour to remove the relevant intake pipes, manifold shield, and tighten up the nuts which were indeed loose.
Here we are about a year later and the same thing is happening. Do I just do an annual "tightening of the nuts" or should I be looking at replacing studs, nuts, and exhaust manifold gasket this time around.
Thanks,
Thanks,
