<br>evo splines:<br><IMG SRC="http://i161.photobucket.com/albums/t215/rushin_album/DSC03548.jpg" BORDER="0"><p>volvo splines:<br><IMG SRC="http://i161.photobucket.com/albums/t215/rushin_album/DSC03549.jpg" BORDER="0"><p>and the input shaft:<p><IMG SRC="http://i161.photobucket.com/albums/t215/rushin_album/DSC03552.jpg" BORDER="0"><p>The only difference is the evo disk is designed for a shaft with sharp splines. the volvo splines as you can see are a bit squared off.<p>Would it be a bad idea to use this disk on the m66 tranny?<br>
Is it the same Spline count? and the Dia. the same?<p>If they are then you it wouldn't be a bad setup, I mean they Build Evo's to high HP numbers so the setup possibility for your S60 would be endless.
I don't think it will work. It looks like the angles are different in the splines... there might be a tiny bit of slop in there = grenaded clutch.
