1 - 11 of 11 Posts
everyone on this forum has been so very helpful, & absolutely awsome,<br>that i thought i may as well push the envelope, & ask if anyone knows<br>a reference site for the evaporative system...<br>seems i developed a "small leak" per my P0442 code.<p>'98 w/148k miles <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: evap. system (volvoom1)
Could be as small as a gas cap
Re: evap. system (JRL)
Yep...make sure it gets several clicks when you put it back on after a fill-up.
Then try the suggestion I made on the thread further down where the same thing is talked about.
Actually it was your own thread. <br>You started so many posts that you haven't check them all huh? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>Here:<br><A HREF="http://forums.swedespeed.com/zerothread?id=63043" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=63043</A>
gas cap will set lage leak not small leak.......best guess without proper testing equipment from volvo........evap valve, sits on lh side of upper radiator
Re: evap. system (atefitty)
Best guess is wrong. It's almost always in the fuel system IN THE REAR
whereabouts in the rear of the system?????? <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Under the car, follow the gas line back to the gas tank...in front of it....a canister and a sensor valve. Check all the lines for leak as well as the valve...I understand the hose called the "J hose" that goes from the canister to the sensor valve is often the culprit. If these aren't them, then it's probably the canister.<BR><BR>
<i>Modified by MadeInJapan at 1:05 AM 8-31-2006</i>
1 - 11 of 11 Posts
