Has anybody used this to replace your coolant? It is a little pricy but appears to have many benefits, including a much higher boiling point, does not evaporate and allows for an unpresserized cooling system and claims to provide better engine cooling<p><A HREF="http://www.evanscooling.com/main21.htm" TARGET="_blank">http://www.evanscooling.com/main21.htm</A><BR><BR>
<i>Modified by jstro at 7:22 PM 7-17-2009</i>
Re: Evans NGP+ (jstro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jstro</b> »</i></TD></TR><TR><TD CLASS="quote">Has anybode used this to replace your coolant? It is a little pricy but appears to have many benefits, including a much higher boiling point, does not evaporate and allows for an unpresserized cooling system and claims to provide better engine cooling<p><A HREF="http://www.evanscooling.com/main21.htm" TARGET="_blank">http://www.evanscooling.com/main21.htm</A></TD></TR></TABLE><p>Snake oil.
Re: Evans NGP+ (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Snake oil. </TD></TR></TABLE><p>Thanks, I though that might be the case but thought the question was worth asking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Snake oil. </TD></TR></TABLE><p>Do you mean it doesn't work?
