1 - 20 of 20 Posts
Hey Guys,<p>I'm new to Volvo's and this may be an old question, so bear with me and no hard slapping.<p>I have a 2001 S60 2.4T with 50K miles.<p>I believe I read that the new ETM has a yellow label. Correct?<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <br>
Re: ETM Module - New or Old (wrodri54)
That is the consensus. The ETM was replaced on my '01, and it clearly has a yellow label on it.
Re: ETM Module - New or Old (wizzard_al)
Doesn't really matter, the yellow tag ETM is the same as the original.<br>You need to clean out your breather box, the ETM and have the new software installed for longevity
Re: ETM Module - New or Old (JRL)
I don't think the point was whether the replacement ETM was better or not, it isn't. The question was whether or not it had already been replaced. Answer, Yes. Good point about the software, which just became available the first week of April. Even the dealers aren't certain what it does, or doesn't do. I"m suspending judgment on the value of the software, but am going to have it installed soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wizzard_al</b> »</i></TD></TR><TR><TD CLASS="quote">Good point about the software, which just became available the first week of April. Even the dealers aren't certain what it does, or doesn't do. I"m suspending judgment on the value of the software, but am going to have it installed soon.</TD></TR></TABLE><p>I've checked mines and it's got the yellow MM label on it. I've had the car for about 3 weeks so not sure when the 1st owner had it replaced. I've never had any software updates on any car so do all dealers charge for software updates/upgrades? and where do I go to find out when new software are available?<br>
Re: ETM Module - New or Old (blackTT55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>blackTT55</b> »</i></TD></TR><TR><TD CLASS="quote">... so do all dealers charge for software updates/upgrades?</TD></TR></TABLE><p>Volvo charges the dealers for each update, so the dealer will pass on the charge to you. Depending on the relationship with your dealer, they may waive it off, but I wouldn't expect it.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>blackTT55</b> »</i></TD></TR><TR><TD CLASS="quote">...and where do I go to find out when new software are available?</TD></TR></TABLE><p><A HREF="http://www.volvotech.com" TARGET="_blank">http://www.volvotech.com</A><br>
I had the ETM software upgrade done for free.<p>Dealer told me it was a campaign 155 (ETM extended warranty)<p>
Can you explain why the breather box has to be cleaned out.<p>Is it part of the ETM?<p>
Re: ETM Module - New or Old (ig_mb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ig_mb</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Volvo charges the dealers for each update, so the dealer will pass on the charge to you. <p></TD></TR></TABLE><br>No, NOT the ETM upgrade, this is a recall and is <B>FREE</B>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wrodri54</b> »</i></TD></TR><TR><TD CLASS="quote">Can you explain why the breather box has to be cleaned out.<p>Is it part of the ETM?<p></TD></TR></TABLE><br>Sort of. if you don't clean it out... <br>1st, the ETM will get dirty and go bye bye <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>2nd, if you don't clean it and allow the car to breath properly, all that oil and sludge has to go somewhere, OUT THE REAR MAIN SEAL!
Any documented procedures on cleaning the ETM?<p>If I take it apart and clean it. Will I have any codes to reset?<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wrodri54</b> »</i></TD></TR><TR><TD CLASS="quote">Any documented procedures on cleaning the ETM?<p>If I take it apart and clean it. Will I have any codes to reset?<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <br></TD></TR></TABLE><br>Bad idea. Unless you're a good tech, let the dealer or a qualified indie do it. They can get messed up permanently, and yes it has to be initialized anyway
Discussion Starter · #13 ·
I would assume it would still be covered by the extended warranty.<p>Am I correct?<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wrodri54</b> »</i></TD></TR><TR><TD CLASS="quote">I would assume it would still be covered by the extended warranty.<p>Am I correct?<p></TD></TR></TABLE><br>Roof rails, not sure. Probably not. Trim items usually are not covered
Discussion Starter · #15 ·
I think you answered back to the wrong message.<p>I was talking about warranty on a replaced ETM.<p>If the new ETM goes out, would it still be covered by the extended warranty (10 years/200K miles)?<p>
You guys do know that the ETM was finally recalled by volvo and if you paid out of pocket to get it replaced, you will get a $900 check back from Volvo. Mine was still under warranty when it was replaced. But the dealership just recently updated the software for it.
Re: (T5Killa)
Yes, it is now being replaced, but the dealer first has to clean the ETM, because the codes are the same, and Volvo won't authorize a replacement without first trying the least expensive alternative. Dealer tells me they are tired of cleaning the ETM and then having the car come back the following week with the same problem, only to replace the ETM which should have been done initially!
10 years, 200,000 miles regardless of how many owners.<br>Yes, they clean out first and apply the new software.<br>My service manager (who does not lie) has told me that cleaning and software fixes over 75% of them (at least for a while) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
My car has the yellow MM label on the ETM so I went back and checked the carfax report on it and the only service reported on the carfax report was done on 10/08/04. I wonder if this was when the ETM was replaced. The description on says "Vehicle Service". Would the dealership or volvo have a record on when it was replaced?<br>
Discussion Starter · #20 ·
Good Question. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>My carfax says service was done at 4,500 miles and it was an Electrical Service, all the other services reported has oil change.<p>
1 - 20 of 20 Posts
