1 - 20 of 20 Posts
Got my EST strut brace today and had some clearance issues during the install. I've attached a few pics to show what I'm referring to. FYI installed on an '08 s40 FWD.<p><IMG SRC="http://farm4.static.flickr.com/3472/3699300161_dcd797c674_o.jpg" BORDER="0"><br><IMG SRC="http://farm3.static.flickr.com/2586/3699316487_aa9b14c7d8_o.jpg" BORDER="0"><p>Should I be concerned? The bolt holding what looks like two ground wires it pressed right up against the driver side strut end.
I had the exact same problem when I installed mine yesterday. It took me over two hours to get it in properly. Not sure what the grounds are for, so I cannot say if there would be a problem with them touching.
Re: (carreragt7)
Id just move that ground to the left and should eliminate the problem you guys are having. Shouldnt be any issue since its a ground post and they share it all together anyway, having them touch is no different.<p>Long as the eyelets on the grounds are the same size anyway, i havent really checked. They look about the same in the pics anyway.
Re: (kpsingh0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kpsingh0</b> »</i></TD></TR><TR><TD CLASS="quote">how did you guys tighten the bolt under the bar?</TD></TR></TABLE><p>You install the mount first then the bar to the mount.<p>IIRC that's what the old bar did also. I'll see if I can't find any old pics.
Re: (mad matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mad matt</b> »</i></TD></TR><TR><TD CLASS="quote"><p>You install the mount first then the bar to the mount.<p>IIRC that's what the old bar did also. I'll see if I can't find any old pics.</TD></TR></TABLE><br>there isn't enough clearence for the bolt that hold the bar to the mounts for you to install the mounts first. O and sould the bolt on the bar be tighten completly
Re: (kpsingh0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kpsingh0</b> »</i></TD></TR><TR><TD CLASS="quote"><br>there isn't enough clearence for the bolt that hold the bar to the mounts for you to install the mounts first. O and sould the bolt on the bar be tighten completly</TD></TR></TABLE><p>Yes the bolt should be completly tight. <p>When I did this on my car I installed the mount first and i too noticed i didn't have enough room to feed the bolt that held the bar to the mount so took the grounding bolts out tempararly so I would have enough room to install the bolt then reinstalled the the grounding bolts. I never had any issues. I'm ginny to bring a tool set to the gtg so if you don't have time between now and then we can get it taken care of at the gtg.
well mine was completely installed but that bolt isn't torqued down. it just as tight as i could tighten it with a wrench underneath the bar.
Re: (kpsingh0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kpsingh0</b> »</i></TD></TR><TR><TD CLASS="quote">well mine was completely installed but that bolt isn't torqued down. it just as tight as i could tighten it with a wrench underneath the bar.</TD></TR></TABLE><p>+1<p>I just got done and couldn't fanagle anything better... It looks sick, let's hope it does something <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>Test drive time, anybody wanna go for a drive to Leavenworth? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Re: (hektikV50)
im not a big fan of the est bar if u can grab it while its bolted on and flex the bar up and down...whats the point i think its for more show than go
Re: (atl-cruisin)
The Size of That Bar it has to Doing - a Lot of Strengthening !<p>What You Don't Want is a Bar that is - So Stiff and So Bolted that <br> It Pushes the Sides or the Strut Tower Out . Now that Sounds Extream<p>Think How Far a 5 ft. bar of Alu. is going to Expand when It goes from<br> 40-60 Degrees to 180 Degree or 215 Above the Turbo .<p>A Stress Relief - That's Why Most Bars have Bends in Them - <br>Usually @ Both Ends .<p>That's Why I Didn't Like the Single Straight Steel Bar - Which was Nothing More then Steel Tubing ( Cheap ) . <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <BR><BR>
<i>Modified by EngTech at 7:54 PM 7-13-2009</i>
Re:
Seems like a pretty decent unit, for the price i dont think anyone lost out. Havent installed mine yet but from the craftsmanship looks alright. I was checking AJ's out at the GTG and its pretty solid. The whole prinicipal is to keep the front chassis from flexing, soon as the suspension becomes unstable or tweaked your suspension geometry is changed reducing your handling capabilities. Obviously you would probably have to drive the car pretty hard to tell a difference but an overall good buy for the price.<p>.02 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
Re: (atl-cruisin)
I didn't think strut bars were meant for more go <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: Re: (ForceFed Motorsports)
Hard , Well If You have Large Tires & Rims and Go Leaning On It , that's Way harder then the Design , so a Bar Will Help .<br> ( The V50's are Stiffer then the V40's Were ) , I didn't have to Go to Much Faster to Feel the Difference On the V40 - about 10 MPH .<p><br>If Everything was Perfectly Tight and You - Started to Expand and Contract<br>The Sides of Your Cars Engine bay 4 Times a Day . 025 Out and .025 Back.<br>Back & Forth - It wouldn't take Long to Loosen Up some Welds and allow Water into some Joints .<p> So there Should be some Flex ( Strut Bar ), But a Good Strut Bar - won't allow this Changing of Suspension Angels 2 Degree On One Side and Nothing One the Other They Support Two Sides , so Everything Should Be Twice as Good - with a Slightly Faster Sway-Bar Action . Real Life It's about a 15% Improvement . <p> Now If they also Tied the Mid Points of the Bar to the Firewall .<br>( Well ,all I can Say is Ka-Boom to the Car that Runs Into that Set-Up ! )<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>Like the Older Cars with a Nice _ V_ Welded to an 18" x 2 " Backing Plate - Bolted to Firewall ! <IMG NAME="icon" SRC="http://********************/smile/emlove.gif" BORDER="0">
there was a group buy for this? damn <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: (heico2.4i)
It was up for like a month and had 35+ some people lol. How did you miss it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
installing my bar (and coilovers) in the garage and getting the same stupid issue.
hope it wont take me 2 hours
1 - 20 of 20 Posts
