1 - 2 of 2 Posts
Hi, I went to my local dealership the other day to run some codes and it got a bunch of messages... I brought it in because of the ETM warranty, but they said it was not that. Mainly ABS errors. Here's the diagnostic message:<p> <I>198753 CHECKED CODES - MULTIPLE CODES PERTAINING TO ABS FAULTS. MULTIPLE COM, CEM, SRS CODES. NONE PERTAINING TO ETM FAULT.</I> <p>The car runs fine to a certain extent, but I would like to get rid of some of these messages. Any suggestions/help?<p>Thanks.
Re: Error Codes (harrr0)
You would first need to know what codes were set then you'd need to address the issues that set the codes. You can't just clear the codes and be done with it--said codes were set for a reason.
1 - 2 of 2 Posts
