Re: (MakoCSH)
As an update for all you DIYers:
The shop lamp method didn't work for long. However, Problem Solved!
Contrary to what the Haynes manual says, there are TWO Outside Temp Sensors, one in each of the side rear view mirrors under the little nipple you see sticking down. I removed the mirror to get to the passenger side sensor, popped it out with a bone tool and cleaned it with Q-tips and alcohol. Voila! Correct outside temperature readings and correctly functioning Air Conditioning
