finally finished engine swap and everything was looking bright until i tried to turn her over. ABS, Service, Check-Engine, and the Winter arrow starting flashing. nothing happened under the hood. i looked into a spark plug and theres oil in one. I'm going to clean each and drop in new spark plugs. what should i check after because the spark plugs are probably not the main issue?
Do the headlights and accessories come on when the key is in position two?
Haha it eventually work with some fidgety ground wires.
The car running and driving now?
The transmission won't shift out of park when the selector does. And it's throwing alot of codes I can't read till I get a new scanner :(
Did you check the shifter cable?
wont have time until i get back from school for winter break :( now it has to sit for another month
