I'm looking at the factory maintenance schedule and it varies by engine vin which is a two digit number. Its a 2004 S60 2.5T. The engine code under the hood says B5254T. What is the engine vin? Or is a part of the vin number and if yes what position in the vin number is the engine vin? <p>Also it appears the fuel filter is only replaced at 120k miles. Seems like a long time is that right? <p>Thanks in advance.
If it is like my car ('98 S70), then it's stamped on a sticker that's stuck on the side of the timing belt cover. Also, on mine, it's stamped on the side and top part of the engine in the aluminum, but hard to see without moving some hoses. Hope this helps.
Re: Engine Vin (ARS6025T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ARS6025T</b> »</i></TD></TR><TR><TD CLASS="quote">I'm looking at the factory maintenance schedule and it varies by engine vin which is a two digit number. Its a 2004 S60 2.5T. The engine code under the hood says B5254T. What is the engine vin? Or is a part of the vin number and if yes what position in the vin number is the engine vin? <p>Also it appears the fuel filter is only replaced at 120k miles. Seems like a long time is that right? <p>Thanks in advance. </TD></TR></TABLE><p>Go to volvocars.us, click on Owners Circle and find your car. You can download the maintenance schedule.<p>Yannis
Thanks. It shows 120k is the correct time to replace fuel filter. Still seems long where most other manufactures say to replace @ 30k.
Banned
Re: (ARS6025T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ARS6025T</b> »</i></TD></TR><TR><TD CLASS="quote">Thanks. It shows 120k is the correct time to replace fuel filter. Still seems long where most other manufactures say to replace @ 30k. </TD></TR></TABLE> <br>30K is an interval for dieselfilters.<br>BTW, the new BMW petrolcars don't even have a fuelfilter only the integrated one in the fuelpump (inside the tank thus) <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
