Went out on my lunch break, rolled over what look like a small piece of sheet metal on accident, heard the metal move on the ground as I rolled over it at like 15-20 mph, and now I got this message on my dash? Yes yes I know check codes, I will when I get home tonight but any ideas on what this could be for?
Just cleared codes last night along with the usual sum cal and other calibrations. Replaced coolant and the overflow tank a few days ago. Is this an urgent message for something serious? Or should I be ok to drive on it for the day?
As long as you are not getting the red triangle and some dire message in in the display and the engine runs fine sounds like you are good to get home.
Should at least stick your head under the car to make sure that metal didn't guillotine something critical underneath the car.
Yeah I only have the yellow triangle and its not on permanently, only when I switch to that message. I will double check underneath when I'm out of work, thanks for the reply!
